KKBKeith Posted July 6, 2025 Share Posted July 6, 2025 I have a plan that has an entry that is technically @ +6", main floor is @ 0", then (2) rooms at -6", followed by a Living room @ -12". I tried using the main floor at 0" and bumped each room either up or down as needed but this resulted in the stemwall foundation being sticking out into the room in the -12" room. So I designated the the Entry as 0" and bumped every room in the house down -6", then took an extra 6" from the other rooms that went down to lower levels & rebuilt the foundation. Everything looks fine as far as levels go but the stemwall concrete finish is now in the room at the lower floor levels. Is there aa more effective way to get the multi level floor working as it should? Thanks, Keith ps. havent even started to figure how to add the missing 6" step down Link to comment Share on other sites More sharing options...
Solution y-g-m-n Posted July 6, 2025 Solution Share Posted July 6, 2025 have you tried setting 0 at the lowest floor level and then inside each room definition for those raised rooms to raise the floor? YOu are using a monolithic CONCRETE SLAB foundation right? Software loves stem walls to Zero level even for lowered rooms and garages. Link to comment Share on other sites More sharing options...
KKBKeith Posted July 6, 2025 Author Share Posted July 6, 2025 Thanks y-g-m-n, This worked far better than anything else I've tried, with a stem-wall. Had to do some fine tuning of room dividers & even re draw some walls a different way to work better with the dividers. I'm just a week into using this software & have not figured many of the concepts. The only issue that still remains unsolved now is a bit of the stem-wall is showing on the interior sides of some walls but I changed the material to the interior wall color or the floor color if it is showing on a step down but the face of the stem wall is set back from the face of the finished wall. Might try mono slab but this is going to be a stem-wall foundation so need it to reflect that. Thanks again for the help. Link to comment Share on other sites More sharing options...
KKBKeith Posted July 9, 2025 Author Share Posted July 9, 2025 When using a stem wall foundation, does multiple floor levels like this cause the top surface of the footings to be raised or lowered in relation to the floor rather than keeping them constant throughout & adjusting the number of courses in the stem wall to raise or lower the slab? If so is there a way to force it to do that? Link to comment Share on other sites More sharing options...
