Whereditgo Posted 16 hours ago Share Posted 16 hours ago All, Using home Designer Pro 2025. For this example, I have specified a Large Rough Opening Clearance gap of 3" on Sides, Top and Bottom. I am trying to create a ICF foundation Layout and include dimensions for the Window/Door Bucks. In the Elevation and 3D Perspective Full View the rough opening shows up, but it does not appear to show in the Floor Plan view. Thought the plan layout would display the rough opening (space between window frame and concrete) in the foundation wall. Thanks in Advance Link to comment Share on other sites More sharing options...
Rookie65 Posted 15 hours ago Share Posted 15 hours ago Do you have your dimensions set to dimension to the rough opening? Link to comment Share on other sites More sharing options...
Whereditgo Posted 13 hours ago Author Share Posted 13 hours ago Are you referring to Default Dimension - Locate Object - Openings - Rough Openings Check Box? If not can you provide additional info on the setting you are referring to? Thanks Link to comment Share on other sites More sharing options...
