IdahoJaci Posted April 17, 2025 Share Posted April 17, 2025 I saw a post from about a year ago similar to my issue, but I didn't understand the response....So here I go. We are changing the siding on part of the house to q/w walls with stone and board and batten. But we are leaving the 2 back walls with the existing cement board lap siding - which we will paint something besides the yucky beige it currently is. We want to audition a few colors to see what will go best. Is it possible to change the color of the cement siding to something besides the few colors offered? None of the colors are even close to what we are shooting for. I did change the exterior wall to plain to get the color I want. But, so much of the character of the wall is lost when it is flat and not showing the laps. The attached picture is the best options in wood lap and cement lap - neither is even close.....Any suggestions? Link to comment Share on other sites More sharing options...
Solution y-g-m-n Posted April 17, 2025 Solution Share Posted April 17, 2025 yes use the SPRAY can paint object option. You click it and then go select your paint color from the library paint manufacturers (can paint it any material that shows up) once selected a little spray can shows up and you have options for how it paints. by floor, room etc etc (CLICK HELP HERE so you understand how it works) Then point and click.... presto color changes Link to comment Share on other sites More sharing options...
IdahoJaci Posted April 17, 2025 Author Share Posted April 17, 2025 Once again, y-g-m-n to the rescue...... Link to comment Share on other sites More sharing options...
