IdahoJaci Posted April 12, 2025 Share Posted April 12, 2025 I have exterior pony walls. The rock extends out farther than the wall above. No problem so far. I want 4.5" deep window sills on the inside. When I set the window to be aligned with the exterior wall I get proper trim until it gets to the pony wall. If I set it to be flush with the inside wall, I get about 1" window sill and the outside has framing showing at the pony wall. I do have 6" exterior walls. I really don't care about all the building stuff in the middle of the wall. This is only for aesthetics - placement, style, color, etc. It is not for plans, or structure. Where do I make corrections so the window shows with a 4" inside sill and sitting correctly on the exterior wall? Do I change the size of the building material within the wall within the wall specifications? Do I change something with the window? Do I change the lower rock wall to only 1" thick so it matches the upper part of the wall? Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 12, 2025 Share Posted April 12, 2025 top left pic looks good? What type of windows? wood, vinyl or aluminum framed? In PRo versio You have control over int & ext sill, header, casings, jamb etc. play with them until you get what you want Way it is made would be the windows installed before siding be it board batten on top or the stone veneer on bottom. Each will have a detail on how it ends near windows and doors etc. Link to comment Share on other sites More sharing options...
IdahoJaci Posted April 17, 2025 Author Share Posted April 17, 2025 Thanks y-g-m-n. I am not sure what I did that fixed it. I changed just about everything I could find. Seems different walls were set up slightly differently. One issue I had was I had wall covering on one wall. Plus on one wall it has one slat of a cement lap exterior that showed up on the inside. I built all the walls one afternoon. and I THOUGHT using the same settings on each wall. But, somehow I dotted my T's and crossed my I's someplace. Only took me another 2 hours to get it all corrected. Now I know to pay better attention when I am doing something.....look deep on every option there is. Link to comment Share on other sites More sharing options...
