glstollfus81 Posted April 10, 2025 Share Posted April 10, 2025 I have one style of wall that I use constantly that is not a default wall type. Every time I open a new plan I have to recreate the wall. How do I save the wall to be a constant default wall option? Link to comment Share on other sites More sharing options...
Rookie65 Posted April 10, 2025 Share Posted April 10, 2025 Create a master plan that you start all of your projects with. Put that wall type into it, and then it will always be available to you when you save the master. Then when you start a new plan, just "Save As' with the name of your choosing, and your master will stay.I also color code the wall framing of each type so it's easier to find each different wall type on a plan for your section details. It's always helpful if you fill out your signature so people know what version and year program you are using. Not every feature is available in each version. 1 1 Link to comment Share on other sites More sharing options...
glstollfus81 Posted April 10, 2025 Author Share Posted April 10, 2025 Great!! That makes perfect sense. Thanks a lot Link to comment Share on other sites More sharing options...
