LYLADRAKE Posted March 4 Share Posted March 4 Hello, I'm not sure what I'm doing wrong, when i create a staircase in the foundation level to the main floor level and it touches an exterior foundation wall, my walls don't line up on the interior. Link to comment Share on other sites More sharing options...
y-g-m-n Posted March 5 Share Posted March 5 I do not see what you are discussing? If walls do not line up check wall thickness as normally program tries to line up studs. or you should line up studs. If not drag them in plan view and use snaps to align studs (main layer) Also you can select stairs and open edit dialogue and turn off handrails against a wall or least turn of balusters etc you need to play more with software to see what it can and cannot do along with click that help button Link to comment Share on other sites More sharing options...
