CostonCapital Posted February 21, 2025 Share Posted February 21, 2025 My plan files were created in HD2014 and there used to be a "transparency" setting for room labels. I've since upgraded my version to HD2024 and I've noticed that when a new room is created, or when a room label is adjusted/changed from the HD2014 plan file, the room label is no longer transparent - see attached. Is there a fix or workaround for this issue? Thanks so much in advance for any assistance! Link to comment Share on other sites More sharing options...
Rookie65 Posted February 21, 2025 Share Posted February 21, 2025 I don't know if 2024 has it, or which version you are using, yet in HD Pro 2025, go to defaults>text, callouts and markers>text styles>room label styles. In there is a spot to make it transparent. Link to comment Share on other sites More sharing options...
