Bound4Wyoming Posted January 11, 2025 Share Posted January 11, 2025 How do you create an awing/roof over a window or garage door in Home Designer Pro 23? Link to comment Share on other sites More sharing options...
y-g-m-n Posted January 12, 2025 Share Posted January 12, 2025 do you have examples? worse case draw manual roof plane.. but ou need something to hold up the outer corners... Link to comment Share on other sites More sharing options...
lukeanthony Posted June 30, 2025 Share Posted June 30, 2025 Use the Room Divider tool to create a small invisible room over the window or door, then add a manual shed roof over it. Adjust pitch and overhangs as needed — works great for awnings in Home Designer Pro 23 santa Clarita Garage Door Repair Link to comment Share on other sites More sharing options...
lukeanthony Posted June 30, 2025 Share Posted June 30, 2025 Use the Room Divider tool to create a small invisible room over the window or door, then add a manual shed roof over it. Adjust pitch and overhangs as needed — works great for awnings in Home Designer Pro 23 Link to comment Share on other sites More sharing options...
