Dartman Posted November 8, 2024 Share Posted November 8, 2024 How do you rotate an object 90 degrees (appliance, cabinet) Link to comment Share on other sites More sharing options...
y-g-m-n Posted November 8, 2024 Share Posted November 8, 2024 in plan view click it. it will show some dims that locate it and if you look around object a small grey triangle thingy. Grab this triangle and rotate. it ill rotate based on your snap angle setting if on or free if off. see screen shot below. Note many other ways to move etc are in the help screen. Peeps should read it or use it when inside a command 1 Link to comment Share on other sites More sharing options...
