Patio concrete showing higher than rest of house
Txcustom
Your main living floor should be at "0". Then set your patio and porches at a negative number and that should drop them down. You can always check your reference manual or the help tab that is on every screen so you don't have to wait for someone to reply
Expand
Thank you. That is working for the floor, but now I am unable to get the "walls" foundation to lower. I am not finding this on the help page.
  On 8/7/2024 at 9:23 PM, solver said:
Think about using cross section and 3D camera tools to understand what the program is doing.
When you take all the defaults, this (section through the door) is what you get. A stem wall and wood floor structure.
Good idea to check (enable) Auto Rebuild Foundation too.
Expand
Auto Rebuild Foundation is on. Just not able to figure out changing the floor height on a wall.
