JamesFL Posted June 7, 2024 Share Posted June 7, 2024 Hello everyone. I am having an issue using Home Designer Pro 2024 where I have several wall types meeting at a certain point and it is causing one of the walls to encroach into one of the adjacent rooms as shown in the image below: The interior walls are all fir framing walls with 1/2" drywall on both sides and fir framing as the main layer. I am trying to have an interior-6 wall meet up to a wall that transitions from interior-4 to interior-10, but the corner is encroaching on the top left room as shown in the circled area. Below is an image from the actual set of plans to better show what I am intending to do: Any help is greatly appreciated! Link to comment Share on other sites More sharing options...
Solution Rookie65 Posted June 7, 2024 Solution Share Posted June 7, 2024 Read up on the wall specification tab>structure>wall intersections and which end of the walls you want to carry through 1 Link to comment Share on other sites More sharing options...
JamesFL Posted June 7, 2024 Author Share Posted June 7, 2024 Thank you for the help! That did the trick. I selected the wall to the left and checked the "Through Wall At Start" option under wall intersections. This stopped the wall on the right from encroaching into the room above. Link to comment Share on other sites More sharing options...
