OldUncleMikey Posted May 17, 2024 Share Posted May 17, 2024 I placed a Kohler K-5827 apron-front sink in my base cabinet/custom countertop but the front edge of the countertop always displays, unless I raise the sink up to the height of the top of the counter instead of making it an undermount, as it's supposed to be. I tried breaking the polyline but deleting the section of the line representing the front edge at the sink merely deletes the entire countertop. Does anyone have experience with this problem? Thanks - Mike Link to comment Share on other sites More sharing options...
Garybills Posted May 17, 2024 Share Posted May 17, 2024 @OldUncleMikeyHey Mike, what version are you using? I just tried it in HDP 2024, and it cut the countertop out. Link to comment Share on other sites More sharing options...
Garybills Posted May 17, 2024 Share Posted May 17, 2024 If you made a custom countertop you will have to select it, break it and shape it around the sink. Link to comment Share on other sites More sharing options...
OldUncleMikey Posted May 17, 2024 Author Share Posted May 17, 2024 Hi, Gary - I'm using Home Designer Pro 2024 build 25.3.0.77 Link to comment Share on other sites More sharing options...
Garybills Posted May 17, 2024 Share Posted May 17, 2024 41 minutes ago, OldUncleMikey said: Hi, Gary - I'm using Home Designer Pro 2024 build 25.3.0.77 Hey Mike, when I put the sink in the cabinet it works right, I made a custom countertop and I did like yours. Yours looks like a custom countertop so I put 3 cabinets together, left the countertops on them and then added the custom top behind them. That worked best because trying to cut the custom top around the sink doesn’t look as good. Hope that make sense and helps. Link to comment Share on other sites More sharing options...
