jlogan02 Posted February 4, 2024 Share Posted February 4, 2024 I'm trying to wrap the brick around the corner in this image so that I have brick below the cedar siding. I'd also like to know the proper way to achieve the 2 siding look here is. For the front portion, I created a railing and configured it to be solid and with break material. Then I drew a wall and manipulated it in the elevation to the correct height on the bottom so it sits on the brick wall. Link to comment Share on other sites More sharing options...
y-g-m-n Posted February 4, 2024 Share Posted February 4, 2024 Searrch in help for PONY WALL. It allows one type of wall on bottom and another on the top portion you decide what is used for top and bottom and the height of bottom. You decide how they should align and what you see in plan view. Best to align main layer as that would be the stud wall. For different width walls normally the wider is on the bottom and they put a CAP on top of lower to hide gap. easy peasy Link to comment Share on other sites More sharing options...
