Plot Plan Dimensions/ Terrain Details/ CAD Blocks/ Showing or hiding text on larger plot plans
BoDay1
Hi,
I'm working to prepare a plan set to remodel a larger single story residential structure with many rooms that sits crookedly on a larger property.
I have drawn the parcel and positioned the structure on the parcel without any difficulty.  I have no confusion about showing or hiding dimensions the conventional way.  However, because of the scale of this project showing dimensions when zoomed out just creates a muddy mess on the building so I have noted the dimensions of the terrain and the building location simply using text so that they continue to appear when I choose not to show dimensions.
But I want the text to be hidden when I choose to hide the terrain.  Can I somehow connect the text I am using to describe dimensions to the Terrain?  So that when I am not showing the terrain the text is also not showing.  Can I use the Cad Block or Architectural Block features in some way to do this/
Thanks,
Bo
Aguilar Plot Plan.plan
