Changing Wall Type
mdag28
when you have brick wall it automatically adds HD's idea of a brick ledge at about 5.5" wide x 3" below slab floor.
SO in your example it probably aligned the outside of the studs and then added brick ledge beyond that.
If all brick house it adds 11" to overall width and length - no way to adjust other than make adjust thickness in the Wall definition dialog
For around where I live HD brick ledge is huge and way oversized for my area and what builders are doing.
I think HDpro should allow the brick ledge size be a variable in foundation slab screen thingy.
