mollybydesign Posted August 3, 2023 Share Posted August 3, 2023 I'm working through the Home Designer - Kitchen Design - Video | Home Designer (homedesignersoftware.com) training video and I notice that on the presenter's screen, as well as my own, interior dimensions for what looks like the same space differ by 1 inch. Why is that? Does it matter? How does the presenter know which one of these to adjust when they are adjusting the walls? Thanks for your help! Link to comment Share on other sites More sharing options...
Solution Rookie65 Posted August 3, 2023 Solution Share Posted August 3, 2023 Look at what the arrows point to. The top is from surface to surface. The lower one is framing to framing. With 1/2" drywall, the one inch difference comes from that. Read through your reference manual for seeing how you can set dimensions to measure how you need for your project. 1 Link to comment Share on other sites More sharing options...
mollybydesign Posted August 3, 2023 Author Share Posted August 3, 2023 Thanks @Rookie65! Link to comment Share on other sites More sharing options...
