Floor Joists Above Basement Garage Not Generating
rawalter
I am currently in the process of designing a home that will be built on a hill and will have a garage as the "basement" area built into the hill with the rest of the house on top of it. The area above the garage should have floor joists but the area not above the garage should be on a monolithic slab. Generating the basement foundation and monolithic slab areas have not been a problem but for some reason I can't get the program to generate floor joists above the basement. Does anyone have any thoughts on why that wouldn't be working? I've tried going through the Build Framing dialog and choosing to build floor framing as a sub frame of floor 1 but for some reason it doesn't generate and when I go back to the dialog the option is unchecked again. Any help here would be greatly appreciated!
14 minutes ago, rawalter said:
Interesting, I actually do have it checked but instead of generating the ~12" floor joists like it should, it just generates a 4" thick ceiling. Thank you for the assistance with this!
You don’t happen to have the room above marked as garage?
12 minutes ago, rawalter said:
Here's the floor above the foundation/basement
If the kitchen is in the slab section and the wood floor section, that’s probably what Is causing it. If so you might have to use a room divider and split the kitchen where the floor is different.
@solver and @Garybills, thanks for you help on this! Adding a room separator wall with a thickness greater than 0" was the key. I added that in around the area above the garage and that fixed the issue! Definitely not intuitive so I hope this helps others in the future that run into this.
