Gable on Bay Window
ChlefUserJohn
Almost there with the "Rectangular Roof Over" option on the wall 45 angle walls of the bay window.
You can see in the real picture that the effect is the front face is shaped like an arrow pointing up.  Is it possible to get that last difference implemented?
Square off the bay by creating 2 small rooms on each side of the bay, using invisible walls.
Open the small rooms and set them as 'open below'.
Set the entire front bay wall (including the front invisible walls) as 'gable'.
If you want to get good answers, then you need to use the correct terminology.
That is not sagging roof material.  That is the ceiling of the tiny room.
Open the room dialog structure tab, and check ' use soffit surface for ceiling'.
