Mulled Windows following roof shape
AudunA
Hi
I am not able to push the mulled windows following the roff shape together in a similar fashion as regular windows.
As can be seen on the attached picture the casing is different on the upper windows.
The plan view shows that windows in both floors are spaced 10mm but the intersection of the windows is represented differently.
Any suggestions on how to fix this?
Home Designer Pro 2019
Build 20.3.0.54.x64
Kjøkken ved gang Vindu 0.5.plan
I opened your plan and a soon as you angle the windows the casing shows up where they are joined together. I found a way to make it look like the lower ones with a little work.
I removed the casing on both the upper and lower windows, then used the custom backsplash tool to create a casing. It will shows as backsplash in the material list if that matters. 594077951_Gablewindows.thumb.PNG.ad74c48fd85709acf6dfb1e88a33ce10.PNG
