AudunA Posted March 19, 2023 Share Posted March 19, 2023 Hi I am not able to push the mulled windows following the roff shape together in a similar fashion as regular windows. As can be seen on the attached picture the casing is different on the upper windows. The plan view shows that windows in both floors are spaced 10mm but the intersection of the windows is represented differently. Any suggestions on how to fix this? Home Designer Pro 2019 Build 20.3.0.54.x64 Kjøkken ved gang Vindu 0.5.plan Link to comment Share on other sites More sharing options...
Garybills Posted March 19, 2023 Share Posted March 19, 2023 I opened your plan and a soon as you angle the windows the casing shows up where they are joined together. I found a way to make it look like the lower ones with a little work. I removed the casing on both the upper and lower windows, then used the custom backsplash tool to create a casing. It will shows as backsplash in the material list if that matters.  1 Link to comment Share on other sites More sharing options...
AudunA Posted March 25, 2023 Author Share Posted March 25, 2023 Thanks Gary. I have no previous experience with custom backsplash so I need some time to test this out, but it looks like a nice method to make large mulled windows. Regards Audun Link to comment Share on other sites More sharing options...
AudunA Posted March 25, 2023 Author Share Posted March 25, 2023 One more question. I have adjusted the window height and some part of the window is now displayed above the backsplash. Any suggestions? I just used bricks on the backsplash to illustrate the problem.Kjøkken ved gang Vindu 1.7.plan Regards Audun Kjøkken ved gang Vindu 1.7.plan Link to comment Share on other sites More sharing options...
