HomeRanger Posted March 7, 2023 Share Posted March 7, 2023 I am working on a design that has a monolithic slab foundation. I can see the slab in 3D view put when I go to Floor 0 "Foundation" in the plan view there is nothing showing up. What I am doing wrong? Thanks in advance! Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 8, 2023 Share Posted March 8, 2023 Open the Room Specification Dialog-Structure Tab and make sure "has floor" checked and also make sure that the "Floor Material" is not set to zero inches (that equals "no floor" visible) DJP Link to comment Share on other sites More sharing options...
HomeRanger Posted March 8, 2023 Author Share Posted March 8, 2023 Thanks for the tips. Both settings were already there. I recently upgraded from Acrhitectural to Pro 2023 and I am starting to think there may be some kind of bug going on here. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 8, 2023 Share Posted March 8, 2023 Post a copy of your plan, and I will look and report, if you wish. DJP Link to comment Share on other sites More sharing options...
HomeRanger Posted March 8, 2023 Author Share Posted March 8, 2023 David, thanks for taking a look! My plan is attached. It was orginally created in Architectural and last saved in Pro 2023. This is a work in progress. It will be at tube steel frame metal building and that is why the walls are 2 3/4" thick. I am mainly working on making a drawing for the slab to get concrete quotes at the moment. Workshop-PA3.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 8, 2023 Share Posted March 8, 2023 You designated the first floor walls as "Foundation" walls, and created NOTHING on "Floor Zero". The foundation shows in camera views because you created the foundation on the first floor and it IS there in plan view and camera views, you created NOTHING on Floor Zero and that is why you see nothing in plan view on Floor Zero. DJP Link to comment Share on other sites More sharing options...
HomeRanger Posted March 8, 2023 Author Share Posted March 8, 2023 Ah! That makes sense, so to try and correct that I did the following: Select all wall types on Floor 1 and uncheck "foundation" walls box Click Okay Select Build > Floor > Build Foundation and check "Automatically Rebuild Foundation" Click Okay Goto Floor Zero and check results --- nothing there? Change the Room Type from Slab to another type, click Okay Goto Floor Zero and check results -- Success! Change the Room Type back to Slab, click Okay Still success! Not sure why I had to do steps 6-9 but it's fixed now! Kudos to you, David for taking the time to look into this for me! All the Best! Link to comment Share on other sites More sharing options...
