Rendering Problems on New Laptop
bixelps
Go to solution Solved by CarrieS,
I recently transferred my HD Pro 2020 license to a new Windows laptop.  I copied all the library files and my plan file appears to have loaded correctly.  But when rendering there are weird shadows in it which I cannot seem to resolve.  This new laptop as a 12th gen CPU and is running DirectX12.   I followed the suggestions is KB-00106 without any success.
What can I do to restore the rendering to the same as I saw on my old Windows laptop.
  • Solution
Hi bixelps,
That darkness can typically be resolved by enabling Texture Compression.
Go to Preferences then to Render and you'll see Texture Compression as the last checkbox.
This article has some additional things to try if you need it::
https://www.homedesignersoftware.com/support/article/KB-00897/troubleshooting-3d-camera-view-display-problems-in-home-designer.html
