ChiefRS Posted November 19, 2022 Share Posted November 19, 2022 I use HDP 2021. I would like to open, modify and share plans with a contractor using Chief Architect X13. My understanding is that CA X13 is compatible with HDP 2022. If this is true, I would like to upgrade to HDP 2022, but the website only allows an upgrade to HDP 2023. My concern is that the X13 user would not be able to open my plans created in 2023. Is there a way to simply upgrade form HDP 2021 to HDP 2022? Thank you, RS Home Designer Pro - 2021 Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 19, 2022 Share Posted November 19, 2022 X13 can read .plan files that you send that user. Once opened and saved in X13 then ONLY HD Pro 2022 will open plans marked for HD P 2022 (not 2021). This has always been the case: no backward compatibility. Personally, I have solved this for myself by running older versions on my computer ( versions 11-24 or X1 - X14) because I specialize in working with HD users who use older versions and Chief Premier Users who, for whatever reason do not see the need to upgrade. I am sorry this is an issue for you, indeed. DJP Link to comment Share on other sites More sharing options...
ChiefRS Posted November 19, 2022 Author Share Posted November 19, 2022 Thank you David. Do you know if I am able to upgrade to HD Pro 2022? It seems like the website is only offering HD Pro 2023? Regards, RS Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 19, 2022 Share Posted November 19, 2022 6 hours ago, ChiefRS said: Do you know if I am able to upgrade to HD Pro 2022? I You can try calling Customer Service but I think the answer will be "NO", sorry. DJP Link to comment Share on other sites More sharing options...
ChiefArchitect Posted November 21, 2022 Share Posted November 21, 2022 Hello RS, Please give our Sales Department a call. We should have an option to help with the file compatibility issue. You can contact us M-F from 7AM to 4PM Pacific Time at 208-292-3400. Kind regards, Derek Chief Architect Sales 1 Link to comment Share on other sites More sharing options...
