Sirfroggis Posted June 23, 2022 Share Posted June 23, 2022 Is it possible to apply edging to a terrain path or terrain feature? I would like to apply cobblestone edging to the driveway and a thin black edging to the exterior of the walkways. I read on another thread that it's possible to do this with a slab or kitchen counter, but I'd rather not redraw the terrain. I'm using Home Designer Pro 2023 (need to update my signature) on a 2021 MacBook Pro with 64gb of RAM. Link to comment Share on other sites More sharing options...
Rookie65 Posted June 23, 2022 Share Posted June 23, 2022 The way I do my edging and patio's is with driveways in the terrain section in roads & sidewalks. Once I have it drawn, I make it the material I want for the edging. Then I will transform/replicate it on the Z axis 1/16" and use the resize option to decrease the size. I then make the new layer the patio material, or terrain in your case, and fine tune the border edge I want, usually 4". I hope this helps? Link to comment Share on other sites More sharing options...
Sirfroggis Posted June 24, 2022 Author Share Posted June 24, 2022 18 hours ago, Rookie65 said: The way I do my edging and patio's is with driveways in the terrain section in roads & sidewalks. Once I have it drawn, I make it the material I want for the edging. Then I will transform/replicate it on the Z axis 1/16" and use the resize option to decrease the size. I then make the new layer the patio material, or terrain in your case, and fine tune the border edge I want, usually 4". I hope this helps? Thanks, Keith. I thought about copying/resizing after I posted, but it seemed like a lot of trial and error to get the sizing right. The detail you provided worked perfectly. Appreciate it! -David Link to comment Share on other sites More sharing options...
