SagoArchitect Posted January 10, 2022 Share Posted January 10, 2022 Hello all, I am trying to "pop up" a roof tower over the stairwell of this plan. There would be a hip on 3 sides of the tower and then return into main roof. How do I POP UP the walls (plate Heights) and tie into main roof with a hip on 3 sides? Also, how do you manually draw columns on an elevation? The 92 Davis Love Temp is the actual plan and the EC03 Study Set is the inspiration. Thanks all. jmpariano Home Designer Pro 2021 EC03 92 Davis Love Temporary.plan EC_03_Study-Set.pdf Link to comment Share on other sites More sharing options...
Rookie65 Posted January 10, 2022 Share Posted January 10, 2022 This is most likely the comment Solver is referring to: "Please post questions in General Q&A. Tips & Techniques is where you share your tips and techniques. Please post images directly -- no need to make a PDF of an image. This makes it easier for others as an image shows in the forum. Make sure you close Pro prior to attaching your plan file. Please delete this thread via Moderator Actions near the top of the page". Link to comment Share on other sites More sharing options...
