chiefid482 Posted February 7, 2015 Share Posted February 7, 2015 Hi All, Just registered, newbie with this software but making progress so far. I've either made a mistake or this is a quirk - but as can be seen from attached files - the upper floor is overhanging the ground floor by more than the depth of the gutter. It's not a huge issue, but I'd be embarrased to submit this to the planning department as they might assume my measurments are out (they're not - seperate drawing). I built the original exterior > Gable roof walls first, then built the first floor, before making the left/right walls gable supporting and finally adding extension at ground floor level. I'd greatly appreciate any advice, as I'm currently a bit red faced over this. Regards, Alex Plan 6.plan Link to comment Share on other sites More sharing options...
Elovia Posted February 7, 2015 Share Posted February 7, 2015 Hi Alex, Welcome to the forum. Is the issue that the left gable wall is not coplanar to the wall below? Or is it more complicated, meaning that the entire upper floor needs to shift to the right by the amount to make that wall coplanar? You can use the align walls tool to fix the upper left gable wall. But if that makes incorrect measurements elsewhere, then you'll need to adjust them to the right by the same amount. After you turn on the reference display to show both floors, you may need to manually adjust the upper wall a bit to get the align wall tool to appear on the object toolbar. Once it does, click it and the walls will align per the default settings. Then adjust all of the other items, including the opposite exterior wall, to get their correct measurements. In your plan, it appears you have the same misalignment for the 2nd floor left and top walls (relative positions in plan view). Hope this helps. 1 Link to comment Share on other sites More sharing options...
chiefid482 Posted February 7, 2015 Author Share Posted February 7, 2015 Thank you for the welcome Elovia, I was able to align the walls with the respective tool (learned something new) and my blood pressure has now significantly dropped. Much appreciate you taking the time to respond, Alex Link to comment Share on other sites More sharing options...
