I have read various comments by users in these forums about the multi-page layout subject,  and I have experimented with the multi-page layout on my own projects -  and show the results I achieved here; Generally it is stated that it cannot be done - but I seem to have achieved suitable results for my work.
So in layout I have created a custom layout sheet size that is dimensionally, 4 x A1pages wide and one A1 page page high;
Using a metric A1 sheet that's a layout that measures 594mm high x 3364mm wide (or long, 4 x 841mm =3364mm)
An A1 sheet is 23" x 33"....approx.
See screen shot attached;
So you can delineate these 4 sheets graphically, I have noted these as Sheet1 - Sheet 4 - just for simplicity here across the 3364mm width and then allocated all the drawing material images, plans, elevations - that is needed accordingly where needed on the 4 sheets;
Then, when ready to print - nominate the target output sheet, in my example this is an A1 sheet  - and save the job as a 4 x A1 sheet pdf file;
I have printed the 4 sheets from the one large layout onto 4 x A4 sheets - 'scale to fit' - just for simplicity here;
Alternatively - I have also printed the layout as a pdf of the same layout size;
Some 24" printers can print one sheet to that length using paper roll feed - not cut sheets;
This can be cut into 4 pages once finished/printed;
As it is that I use A3 sheets predominantly with drawing output - I am experimenting in testing the limitations of the layout maximum width.
According to CA - there isn't any limitation.
The results are satisfactory for my multi-page needs and use - from one layout.
( Note - the output nominated  print size was adjusted slightly to suit the total page width.)
Happy days.
2021_Trevellyan as 4 printed sheets.pdf
