Stud only wall
Ric_VA
Using Home Designer Pro, 2021
I am trying to create a wall in the crawlspace to support the floor above.  Trying to get it to be studs only, no drywall or other material.  16" CC to align with joists
So far only able to get wall with layers on it.
tried to copy and created new wall, removed drywall layers. still shows solid wall in 3d
Edited by Ric_VA
updated information
Thanks for the suggestions.  The only way I got it to display as desired was to make it a rail, all suggestions above did not work for me. The posts display as a square instead of a 2x6, I will just make a note on the plans
