Importing survey
D3o6n1
If you will look under "File - Import-GPS Data" if you have such a data file you can use that feature. You can scan a topological map and then import the resulting image, then make sure the image is properly scaled and then trace over its topo lines using provided topo elevation splines or lines. Another method under the "File - Import" area is to import "Terrain Data" in the form of "X, Y, Z coordinate" etc formats of which there are many to choose from (take a look for yourself). This is all explained, in detail in your Reference Manual under "Terrain".
