bmatth1 Posted June 17, 2020 Share Posted June 17, 2020 I have an opening on a deck that I created a header using framing / build / ceiling beam. How can I add a door under the header in plan view. Looks like my problem is with having multiple objects in the same space in plan view - beam and door under. I am using Trial HD Pro. Link to comment Share on other sites More sharing options...
bmatth1 Posted June 17, 2020 Author Share Posted June 17, 2020 Problem solved. I deleted the beam, closed the opening and made it a full wall, added the door, and HD PRO added the header at the top. Link to comment Share on other sites More sharing options...
