bmatth1 Posted June 9, 2020 Share Posted June 9, 2020 I created a railing beside the stairs, then a railing around the deck then connected the two at the top of the stairs. As you can see in the pictures, there is an almost invisible door that was created under the rail at the top of the stairs. I have made the materials for that door to be NONE, but there still remains a couple of strips that I cannot get rid of. Suggestions? I am using the trial version of Home Designer Pro. Link to comment Share on other sites More sharing options...
bmatth1 Posted June 9, 2020 Author Share Posted June 9, 2020 Ok, most of the unwanted lines are gone now. However, under the short railing, there is still a couple lines under the deck - cannot find where to eliminate these. HD Pro Trial. Also post up against the house is not needed - how to eliminate. Link to comment Share on other sites More sharing options...
