AlsDesigns Posted December 10, 2014 Share Posted December 10, 2014 I just installed Home Designer Suite 2015, and I'm having an issue with 3d views. In the 2d view I place a camera and a new window opens up, but nothing appers in the window. If I click in the area, the view shows up, but as soon as I move the mouse the picture disappears and so I can't do any editing in the 3d view. Am I doing something wrong? Thanks Al Link to comment Share on other sites More sharing options...
katalyst777 Posted December 10, 2014 Share Posted December 10, 2014 More than likely a problem with your video card. Make sure it meets the System Requirements for running the software, and if so, update its driver following the instructions in this Knowledge Base article - http://www.homedesignersoftware.com/support/article/KB-00897/ 1 Link to comment Share on other sites More sharing options...
AlsDesigns Posted December 10, 2014 Author Share Posted December 10, 2014 Thanks for the quick reply.... I ran across that information after posting this, but sad to say, Toshiba doesn't have any newer drivers for me :-( I saw somewhere that I might be able to improve things by changing something about rendering, but I took a quick look, and don't know what to change. Thanks Link to comment Share on other sites More sharing options...
Solution AlsDesigns Posted December 10, 2014 Author Solution Share Posted December 10, 2014 OK, I went back and re-read the document you sent, and followed the instructions at the end and now the 3d views show up and seem to be working more as expected. THANK YOU!!! Link to comment Share on other sites More sharing options...
