ahecht Posted November 21, 2014 Share Posted November 21, 2014 I'm new at this.. I have a daylight basement, created the walls and all, but the floor is just a big empty space. Can't add carpet, etc. I must be missing something obvious..? Thanks! Anthony Home Designer Suite 2015 - Mac Link to comment Share on other sites More sharing options...
Elovia Posted November 21, 2014 Share Posted November 21, 2014 Welcome to the forum, Anthony. Try building your daylight basement as the first floor level. Hope this helps. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted November 22, 2014 Share Posted November 22, 2014 can you post your plan ie attach it to a post via the more reply Options button.... M. Link to comment Share on other sites More sharing options...
katalyst777 Posted November 24, 2014 Share Posted November 24, 2014 Make sure your walls create an enclosed space. If you select it, the "Room" should highlight. Also make sure that "Room" isn't set as Open Below. Link to comment Share on other sites More sharing options...
