Vertical split of materials on a single wall
DavidSp
Depending on which Home Designer program you have, you can use the "split wall" tool to define the sections of walls you want to break into each finish type. Then open that wall and change the interior material to either paint or tile.
Thanks, that helped a lot. I have Home Designer Interiors 2019.
Break Wall was the command I used.
Edited by DavidSp
Grammar
