Problem creating roof
tyboehs
Here is a plan using auto built roofs that should get you going. I'd add the porch roof manually after the other parts of the roof are correct using the auto builder.
Using your plan,
Go to Edit>Reset To Defaults, choose all floors and check all the options.
Go To Edit>Delete Objects, choose Roof Planes and Roof Baseline Polylines.
Delete the 2nd floor and the Attic level. (Build>Floor>Delete Current Floor)
Turn on auto rebuild roofs, then change the settings to make the roof work. Don't check Make Roof Baseline Polyline as it's not needed.
Ty's Dream Home (eric).zip
