tyboehs Posted November 15, 2018 Share Posted November 15, 2018 I am new to home designer pro 2019 and am trying to create a roof on my plan and am having difficulty making it work could somebody help me out. The file I am posting is all messed up and i cant even get it back close to right Ty's Dream Home.plan Link to comment Share on other sites More sharing options...
solver Posted November 15, 2018 Share Posted November 15, 2018 9 minutes ago, tyboehs said: cant even get it back close to right What is "right"? If it's an existing house -- post images, if not, someone needs an idea of what you want via a drawing or other. Link to comment Share on other sites More sharing options...
tyboehs Posted November 15, 2018 Author Share Posted November 15, 2018 I have it drawn with sketchup can anyone open that kind of file? Link to comment Share on other sites More sharing options...
solver Posted November 15, 2018 Share Posted November 15, 2018 Just take a couple of screen captures and post them. Link to comment Share on other sites More sharing options...
tyboehs Posted November 15, 2018 Author Share Posted November 15, 2018 Link to comment Share on other sites More sharing options...
solver Posted November 15, 2018 Share Posted November 15, 2018 Here is a plan using auto built roofs that should get you going. I'd add the porch roof manually after the other parts of the roof are correct using the auto builder. Using your plan, Go to Edit>Reset To Defaults, choose all floors and check all the options. Go To Edit>Delete Objects, choose Roof Planes and Roof Baseline Polylines. Delete the 2nd floor and the Attic level. (Build>Floor>Delete Current Floor) Turn on auto rebuild roofs, then change the settings to make the roof work. Don't check Make Roof Baseline Polyline as it's not needed. Ty's Dream Home (eric).zip Link to comment Share on other sites More sharing options...
tyboehs Posted November 15, 2018 Author Share Posted November 15, 2018 Thanks I will try that, how do I make the little gable on front 10/12 instead of 8 Link to comment Share on other sites More sharing options...
tyboehs Posted November 15, 2018 Author Share Posted November 15, 2018 how do i make the main roof sit on the front wall instead of porch beam? Link to comment Share on other sites More sharing options...
