andyta Posted October 27, 2014 Share Posted October 27, 2014 Hi, When clicking auto interior dimensions the dimension line starts from outer side not inner side of the wall ( see attached picture). Is there setting somewhere to make dimension start from innder wall side ? Link to comment Share on other sites More sharing options...
katalyst777 Posted October 27, 2014 Share Posted October 27, 2014 I'm not getting the same results. What version of the program are you using, and which template style did you start the plan from Link to comment Share on other sites More sharing options...
Kbird1 Posted October 27, 2014 Share Posted October 27, 2014 Check Edit>Defaults>Dimensions> Check all 3 are setup correctly for wall surfaces,both sides etc. M. Link to comment Share on other sites More sharing options...
andyta Posted October 27, 2014 Author Share Posted October 27, 2014 Thanks for replies. My sw version is 2015 Pro, and I started with Urban Chic template Problem appears every time if I use user defined walls, for example if I copy the wall type Stucco-Thick , change it's thickness and then use it as a default wall then the dimensions are positioned wrong. But what's strange , the problem appears only if all exterior walls are user defined or copied - if I have at least one default wall type in plan then dimensions are just right. Andy Link to comment Share on other sites More sharing options...
Kbird1 Posted October 28, 2014 Share Posted October 28, 2014 When you define the wall , do you retain the "main layer" as the framing ? and make sure the check boxes for dimension to this line are checked still / are on the right layer? Tech Support may not be aware of this if you think it is a bug call them or emial them so they can look into it before the next Patch... M. Link to comment Share on other sites More sharing options...
katalyst777 Posted October 29, 2014 Share Posted October 29, 2014 Thanks for the additional info. I agree that it sounds like you've changed the Main Layer of the wall so that it is no longer correct with your custom wall type. Link to comment Share on other sites More sharing options...
