1 3/4 story
theallan
First up, I'm using Home Designer Pro 2019.
I'm trying to draw up a 1 3/4 height house (I'm sure it has a technical term which I'm not aware of - apologies). Attached is a little paint mock up image of the second story end elevation - the wall is intersected by the plane of the roof, cutting it off about half way up. I'm guessing that this probably needs to be a knee wall, but if I select that option there isn't any option to set its height. Or perhaps I need to set the roof baseline, which I can't find an option for, or something else.
I found the documentation for a 1 1/2 story house, but I can't see how to have 90deg walls for part of the height.
**edit** This image shows more or less what I am trying to do: http://www.scotframe.co.uk/SelfBuild/HomesPortfolio/134Storey/Orange.aspx .
Thanks,
Allan
