Hi, I'm using Home Designer Pro Windows 64 bit 2018. I'm creating a fake balcony with inswing double doors and a decorative iron railing balcony bolted to the exterior. When I try to place this it drops to the ground or it installs posts to hold it up! Where can I go in the program to find or create a purely decorative faux railing/balcony on the 2nd floor of my project??
Thank you!!
Helping_Hand
What you are describing is called a Juliet Balcony.  I found one in the library called a Mediterranean Balcony.  Unfortunately, I can't figure out where I found it within the library (Core or Bonus) but when I open the object it says "Copyright 2010, Chief Architect, Inc." so it must be squirreled away in there somewhere. (See attached image.)  I stuck one of the outside of the house and placed double doors to access it and it does not generate support posts when added.  There may also be some on 3D Warehouse.  Hope this helps.
Edited by bluesparrowllc
Added Balcony image...
