Plot Plan Lines
DIYAdam
Hello Users
I'm in the process of creating a plot plan and the trouble I'm having is the plot lines that I created keep changing bearing angels,length,end points. I tick the radio button to lock the bearing and length. The line looks good until I convert a line to arc then it really changes the lines connected the arcs.
Thanks
All bearings are relative to an established "North Pointer", have you created a "North Pointer" yet? If not then carefully establish one as this is the stable datum the software uses to create and communicate bearing points. If no "North Pointer" has been created then the software "assumes" that straight up is "North" on your plan view screen.
If you require more precise advice on this matter please contact Chief Architect Tech Support and or your included Reference Manual for detailed information on how to use the input line tool.
