thunderbolt Posted June 6, 2017 Share Posted June 6, 2017 How do I create an exterior wall under a shed roof? See photo Link to comment Share on other sites More sharing options...
solver Posted June 6, 2017 Share Posted June 6, 2017 1) Please fill out your Signature -- see below. 2) You draw it just like any other wall. -------------- It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
thunderbolt Posted June 6, 2017 Author Share Posted June 6, 2017 The small triangular part of the wall is exterior. Inside, under the shed roof, there is no wall. I've explored many of the educational videos. If I created an "Invisible" wall, wouldn't that make the triangular part invisible too? I don't know how to delete my redundant question? I can't see how to delete it "... under options at the bottom of your post" There is an "Edit" option but not a delete. Link to comment Share on other sites More sharing options...
solver Posted June 6, 2017 Share Posted June 6, 2017 You are trying to make the wall thing more complex than it is. Where is the wall located -- the 2nd floor level. Go to the 2nd floor, turn on reference display so you see the walls below, draw a wall where it needs to be. Adjust as needed. If there was an interior wall directly below, the program would probably fill this in automatically. Link to comment Share on other sites More sharing options...
