SammyBB Posted May 5, 2017 Share Posted May 5, 2017 I have Home Designer Pro 2018 on Windows 10, and I'm trying to put a roof and ceiling over my wrap around porch. My two end walls on the house are gable walls and the roof plane is fine when the porch isn't covered. Auto-rebuild is on, but when I go to check the full overview of the house, the roof planes over the house are missing. I've tried everything from setting the pitch to a lower value on the porch, but nothing seems to work. Any help would be appreciated!! Link to comment Share on other sites More sharing options...
solver Posted May 5, 2017 Share Posted May 5, 2017 1) Please fill out your Signature -- see below. 2) Because this is a question, it should have been posted in Q&A (Questions and Answers). Tips & Techniques is where people share Tips & Techniques. 3) There are several ways of doing this. The simple way using auto rebuild roofs is to add a 2nd floor -- think of it as the attic, but don't set the room type to Attic or you won't get a roof over it. This complicates the model because you then need to change things to make the structure accurate. With Pro, you could use manual roofs, turning off Auto Rebuild. For the porch roof, research the Upper Pitch option in the wall dialog Roof panel. -------------- It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click Account Settings, then Signature on the left. Doing so makes it always available, and this info is often key to providing a good suggestion Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
LawB10 Posted May 5, 2017 Share Posted May 5, 2017 Build a second floor, then lower the ceiling height to 0". Open the deck specification box and check "roof over this room" and then lower the pitch on each rail to 4" or so.... Link to comment Share on other sites More sharing options...
