tgidave Posted April 14, 2017 Share Posted April 14, 2017 Hi, Is there a way to attach the railing of a deck to the outside of the joist instead of on top of the planking? Thanks in advance, Dave Link to comment Share on other sites More sharing options...
Elovia Posted April 15, 2017 Share Posted April 15, 2017 I messed around with modeling deck railing attached to a fascia board back in 2009 on the old forum. http://hometalk.homedesignersoftware.com/showthread.php?15329-direction-of-the-decking&p=64409#post64409 As Eric mentions ... yes, it can be done but not easily. Although if you have practice with the tools, it isn't all that hard either. The downside is that doing it the way described in the linked post doesn't allow you to easily modify the size of deck or relocate the railing if you need. Such is the life using custom details. Good luck. Link to comment Share on other sites More sharing options...
tgidave Posted April 15, 2017 Author Share Posted April 15, 2017 Thanks to both of you! I will give this a try. Thanks again, Dave Link to comment Share on other sites More sharing options...
