bigriles Posted January 18, 2017 Share Posted January 18, 2017 I'm having trouble drawing raised panels on back side of a run of cabinets. when I "open object" its showing my the front side when I want to get a blank slate to layout panel design. I need a quick refresher thanks. (homedesigner pro 16) Link to comment Share on other sites More sharing options...
Cube1us Posted February 7, 2017 Share Posted February 7, 2017 Same issue in Interiors. I fear that this is probably "as designed", aka "crippleware" of the Home Designer series. The Chief Architect professional series (*not* Home Designer Pro) can do this - I found a knowledge base article for that series that shows a cabinet dialog that says "front/sides/back", whereas in H.D. Interiors it just shows "Front" in that dialog. One can rotate the cabinet to *look* at the back in the "Base Cabinet Dialog", but you cannot select it or modify it. In looking at the product comparison chart, this is not an area that lists differences in the various Home Designer line. (Personally, I think this really sucks). Link to comment Share on other sites More sharing options...
ImLon2 Posted February 7, 2017 Share Posted February 7, 2017 Here is what I did. I created another cabinet and made it the same width as the cabinet it is attached too, and then made it 1" in depth and flipped it around facing away from the other cabinet (butted them together back to back). I then deleted the drawer, knob, and toe kick. If you want an over hang you can add it to the new cabinet you just created. I did have to mark all cabinets Flat Sides to make it look right. If you want the slight over hang on the sides you can create just a counter top by... creating a new cabinet and make it 1.5" in Height, then make it 36 floor to top.. you can adjust the width at this point to match the cabinets you are currently working with. Hope this make sense. Link to comment Share on other sites More sharing options...
katalyst777 Posted February 7, 2017 Share Posted February 7, 2017 Lonnie's suggestion will work. Another option is that you can also just place cabinet doors and drawers as independent objects. They don't have to be applied to the cabinet directly to create the look you want. Link to comment Share on other sites More sharing options...
