arcways stair newels and balusters
AniaBogustawa
Go to solution Solved by katalyst777,
  • Solution
Home Designer doesn't let you change the Newels/Balusters associated with a staircase directly.  BUT, you can set their material to "Opening (no material)" so they don't display, then put the wrought iron scrollwork items from Arcways and adjust their heights to follow the stairs.
I don't know of a good way to create the volute on the ends though except maybe importing something close from SketchUp
  • 1 month later...
