Attic Wall auto-generates with Manual Roof
PLANsLLC123
To All,
I am just beginning to use Manual Roof mode in HDP 2016.  I have generated my initial roof section over the exterior wall, but in section view I see it is not sitting on the exterior wall, but has generated a 2'-8" 'Attic Wall' above the existing exterior wall for the roof to sit on.
I am sure one of my settings is off, but can not figure which it is.
Any help is appreciated.
Tim
Pelster Remodel-Front Porch & Entry.plan
I can't find any roof planes in the plan you attached, but it sounds like you just created it too high.
Double check all the videos and articles on manual roofs and make sure you understand the roof baseline stuff and editing manual roof planes.
If you already have a version of the plan where it's drawn wrong, select the roof plane and use Transform/Replicate to move it down by putting in -2'8" for the Z axis.
Thank you for the advice.  I will continue to review videos and articles on manual roofs.
I somehow fixed this since posting the message.  One of the settings (can't remember which) had the roof setting 24" above ceiling plane?
Thanks again for the help,
Tim
