Bullnose Verandah
aussuab
Go to solution Solved by katalyst777,
  • Solution
If you have Pro, you can try using similar steps to what's discussed in this article.
KB-01187: Creating a Barrel Roof
However, that's a lot of work to get just right.
The Premier version has actual curved roof tools.
You can probably fake the look using something like an "Awning," but you'll have to adjust the material applied to it to be pretty small if it's corrugated like your image so that it doesn't quite look so odd when tiled across the curved surface.
