aussuab Posted April 19, 2016 Share Posted April 19, 2016 How would I go about creating something like this? Link to comment Share on other sites More sharing options...
solver Posted April 19, 2016 Share Posted April 19, 2016 -------------- It helps if we know what title (Suite, Pro etc) and version (2014, 2015 etc) you are using. You can add this info to your signature by clicking on your user name at the top right of the page, click My Settings, then Signature on the left. Resources for self help: The built in Help System (always a good place to start) Getting Started Knowledge Base YouTube Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted April 19, 2016 Solution Share Posted April 19, 2016 If you have Pro, you can try using similar steps to what's discussed in this article.KB-01187: Creating a Barrel Roof However, that's a lot of work to get just right.The Premier version has actual curved roof tools. You can probably fake the look using something like an "Awning," but you'll have to adjust the material applied to it to be pretty small if it's corrugated like your image so that it doesn't quite look so odd when tiled across the curved surface. 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted April 20, 2016 Share Posted April 20, 2016 You should also check out your other carport post where Jo_Ann did a better example of creating the bullnose verandah and used a different method of a custom countertop with a bullnose edge molding.https://hometalk.chiefarchitect.com/index.php?/topic/2280-carport/?p=12753 1 Link to comment Share on other sites More sharing options...
aussuab Posted April 25, 2016 Author Share Posted April 25, 2016 thank you! Link to comment Share on other sites More sharing options...
