Timeless_16 Posted April 8, 2016 Share Posted April 8, 2016 Hi All,I thought I had it set up for so that the roof would move if I moved the wall at least it has been before. Apparently, it's not set to correct dimensions when exterior wall is expanded. Is there a quick fix for this? Below I attached the view that shows the gap in the roofing. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 8, 2016 Share Posted April 8, 2016 When you are not using "Auto Rebuild Roofs" it does not update as you change wall locations (as you have seen), rebuild roofs AFTER you make your wall location changes. If the auto rebuild roofs tool screws things up or misses your outcome, you manually edit the results of the roofs until you do have what you want. DJP Link to comment Share on other sites More sharing options...
Timeless_16 Posted April 8, 2016 Author Share Posted April 8, 2016 Thanks David, that worked! Link to comment Share on other sites More sharing options...
