scarletto Posted February 2, 2016 Share Posted February 2, 2016 I think I've finally got things set up now so instead of asking about errors, I am ready to start designing, and now I have what I think should be a basic question, but I am not able to figure out how to set the height of a wall? Link to comment Share on other sites More sharing options...
Solution katalyst777 Posted February 2, 2016 Solution Share Posted February 2, 2016 The answer to that is going to depend on WHY you want to change the wall height.Want to change the height of the ceiling in all rooms? One room in particular? Create a half or partial height wall? A closet with walls that aren't as high as the rest of the room?All these situations are covered in this Knowledge Base article.KB-02969: Changing Wall Heights For future reference, you can just use the Search box on the main Home Designer website or on the Knowledge Base page (if you use the search in this forum, it only searches HomeTalk), then go to the "Support Database" tab in the search results to see applicable articles. Link to comment Share on other sites More sharing options...
